raised floor in control room
I think I'll pass on this one, but I like the way you've squeezed two people into the smallest office! :mad:
Would it not be more like building regulations you need to be looking at? :confused:
G.
Id say if its for flooding then whatever height you use - the flood will be at least double that
We call it sods law in the UK
The question you need to be asking is what is the raised floor being used for. In several facilities I worked in, the area under the floor was also the air plenum for HVAC. If that is the case here that will dictate what heights you will need.
I've typically seen 12" to 16". This seemed sufficient for most cases I've been involved with.
Remember the OP said optimum.
From my experience the optimum would be seven feet - this way you do not need to lay on the floor and have people step on you. AND for Petes sake put in some lighting.
Dan Bentler
The old IBM mainframe servers had a 3' space under the floor for all the cables going back and forth. On the other hand, I have designed factory control rooms with no underfloor space (cables routed in ceiling and down through vertical wireways).
Many ways for solving.
1. Decide the amount of cables that will be running there and the needed height(When I get the value, I'll multiply it with 1.2-1.3, just for future reservation)
2. If you have preliminary info about the cables, just select raised floor system(if you use a ready one, but not building it on your own) and check which type of "legs" for the floor will match your needs
3. Even though the answer "7 feet" is the best, you can always check, or change a cable without bending or crawling.
If a large project, just calculate some minimal height and let the architect chose the rest
Dear all,
thank you for your valuable responses, however, I was thinking that 7 feet which is 2m for a raised floor that would be passing cables only, seemed I guess quite a height....I would go for 12' = 30 cm would be fair I guess.
good day,
Hello everyone... I have a problem and i want your help. I installed Wincc V7 SP1 &SP2. The installation was done normally without any problem...
2,128
I had a Brady rep in last week and he had a demo of these new button labels. Has anyone used any of them? I engrave everthing now and this looks...
1,712
Hey guys , I have included a couple attachments here , one of what I was supposed to come up with a program and the program I came up with. Does...
3,108
In the late 90's I worked in a factory that started replacing the diamondplate steel around their presses with plasma etched steel plates. They...
1,817
Can anyone share the hardware/software in integrating Radio-frequency identification (RFID) security on a plant floor's OEM machine HMI's? I...
2,963
