HMI datalogging to USB from CF port (or remote CF port)
strantor
Sep 2010
katy tx
401
My Omron NS15 HMI saves tend plot data in *.CSV files, but only to Compact Flash cards, not USB (that I know of, correct me if I'm wrong). I do not want the operator to have to open up the display panel to retrieve the CF card from the back of the HMI. I'm looking for an on-device Compact Flash to USB adapter; something with a CF-interface on the front end that plugs into the HMI's CF port, and a female USB port on the back end, to which you could insert a USB thumb drive (or in my case, a USB extension to panel mount USB port, where thumb drive will be plugged in).
Does such a thing exist? All I can find on the web are inversions of what I need; remove the flash card, insert into device, plug device into PC USB port.
Failing that, does anybody know where I can find a panel-mount Compact Flash port with extension cable?
Hello, I have a Magelis HMI STO501 and I am using Vijeo Designer 6.2.8. I need to transfer data configured in data logging group to a USB flash...
2,289
Hello plctalk, new guy here. I have an application that I'd like to present for your considered opinions so I can figure out what hardware I...
2,504
Hi everybody! Normally I work with Beijers panels only but now a customer has a couple of Siemens panels (MP277 10" Touch and MP377 15" Touch)...
2,352
Calling all Profibus experts. I am considering to use the S7 CPU 315-2 as a standard device for our various control tasks/machines. In that...
4,876
Hi I have a couple of hmi panel view plus 700 Hmi and we keep dropping coms /stars in the data boxes I’ve checked the plc and unmanaged switch...
140
