Connecting S7 200 PLC with PC
Unregistered
Guest
U
Hello
I have such a problem, that i have PLC and MicroWin...but i dont have a special PC/PPI cable.
Is it anyhow possible to connect without special cable?
Can this cable be made by some drawings from the web or can i connect PLC and PC with cable what is used to connect PLC with TD200?
Thanks,
Ivan.
Hello Yvan;
The programming port of the S7-200 "talks" PPI; either you use Siemens' PC/PPI cable to convert fron RS-232 to PPI, or you use a comm. card that is configured for PPI (such as the CP5611)to connect.
Unfortunately, it seems Siemens protects the secrets of its converter cables very neatly. There are quite a few posts here on PPI and MPI converters, and none seem to have a solution besides buying the original Siemens products.
Hope this helps,
Daniel Chartier
I also found the new USB to MPI converter that Siemens has also allows comms on PPI to the S7-200. This is a lot more expensive than a PPI cable only. For me, since I use the entire range of S7s, it is worth it.
Ivan
Like Daniel said you need the cable... Siemens has two low end cables avaliable...
One for RS232 to PPI ( 6ES7901-3CB30-0XA0 )
or USB to PPI ( 6ES7901-3DB30-0XA0 )
They are plug and play with the MicroWin software...
Galic64
Are you talking about siemens multimaster cable?Can it be used for s7 200 and s7 300 programming?I wish to buy one ,my plc friends any comment about this cable?
Take the PC-Adapter (USB edition only). They ship them with a PPI driver
on CD. You need Microwin >= V4.0 to use this.
Hello all. When I try to connect to a S7-1200 PLC (Tia Portal v17) which has a CP 1243-1 module that is connected to my clients network I get...
1,494
Hi All, I have a closed loop stepper motor (Nanotec make), https://en.nanotec.com/products/2512-pd4-e601l42-e-65-4. This uses MODBUS TCP for...
3,844
I want to connect s7-1200 (master) to Arduino(slave) by modbus RTU and read its Holding registers. I connected arduino to Modbus poll software...
18
17,398
Hi there I am new with this thing and i don't know how to connect Allen Bradley Micrologix 1200 PLC to Raspberry Pi using USB to RS485 in NodeRED...
2,270
Hello all, I'm working with an s7-1200 and a stepper motor in Tia portal v17. This stepper motor is an SMD23E2 and I am attempting to connect...
19
2,842
