Cannot Communicate with PLC Error while connecting to FX2-48MT
pdk153
Jul 2003
Hey,
Im trying to connect to Fx2-48MT PLC with GX-Developer through my serial port on one side and RS232C on the other. Anytime i try to connect with the plc i get the message "Cannot COmmunicate with the PLC. Execute again after checking the connections with the PLC." This is my first time doing this and I am not sure what is wrong, how can i connect this plc with my computer? I just need it to practice on it. Thanks!
You need a 232 to 422 converter like the SC09 cable as the ports on all mitsi apart from the "Q" series are 422.
However, there is a thread on here somewhere about making a connection from your 232 port to 422 without the SC09 converter, but be aware, I have not tried this & it would be at your own risk.
If you search this forum you should find it.
I have a 1756 L62 ControlLogix5562 controller I cannot connect to via ethernet. Get RSLinx cannot communicate message. Verision 19. It has a...
1,670
Greetings everyone, We currently are using Somachine 4.3 with an M241 processor and a HMIG5U2 w/ HMIDT732. This is my first time using this HMI...
3,438
Welcome all! //tldr on post end At first I would like to introduce myself, my name is Paul and I really like this site, but just recently I was...
2,642
Hi all.. I have Honeywell HC900 at my factoy. Recently I try to download some function blocks that I made before to it. But when I try to...
3,909
I am trying to communicate the my L61S CPU, but Linx will not see it using a Serial or Ethernet connection (via my other module). The OK indicator...
1,787
