H_Kiani Member H Join Date Nov 2016 Location Toronto Posts 1 Jan 20, 2018 #1 Hello Everyone, Have you come across or do know an AB PLC that is Oil / Moisture resistance ?
rupej Member R Join Date Sep 2014 Location NC Posts 967 Jan 20, 2018 #2 Not sure about the PLC itself, but don't AB and many others make IP66+ I/O modules? You would just use them as remote I/O for a PLC mounted in a clean and dry area.
AustralIan Member A Join Date Jan 2013 Location Leipzig, Germany Posts 1,368 Jan 20, 2018 #3 The closest I know is the Armor CompactLogix. You can also buy enclosures that are oil and moisture resistant, and put the controller inside of it. Make sure you keep him nice and warm, too.
jstolaruk Lifetime Supporting Member J Join Date Dec 2004 Location Detroit, SE Michigan Posts 3,910 Jan 20, 2018 #4 AustralIan said: The closest I know is the Armor CompactLogix. You can also buy enclosures that are oil and moisture resistant, and put the controller inside of it. Make sure you keep him nice and warm, too. Click to expand... And the Controllogix version (5570). I see claims for extended temperature ranges but no IP rating unfortunately.
