I am trying to talk to a Spectrum Controls SOI 200-AB that has a RS485 using a PC serial port. Any clues or knowledge will greatly be appreciated.
thanks for any help
reed
It looks like you can use DIP switches to set up the communication ports in RS-232 mode, which would make it straightforward to connect to your PC's RS-232 port.
If you want to talk to it in RS485 mode, you're going to need a compatible converter. I like B&B electronics units, but have no experience with using them with this old HMI device.
