S7-400 communication PDV to PLC problem
TBMALEPPO
Mar 2008
aleppo
We are using siemens S7-400 analog-inputs (SM431 6 ES7431-1KF00-0AB0) and PC for data acquisition via PDV software to absorb, process, visulise and to evaluate all data arising in connection with the tunneling machine.
The communication between screen PC and PLC have a problem e.g. important limiting values, control parameters such as temperature, maximum and minimum distance for steering jacks and other values which have to be adjusted via a screen after put in and adjustment it could not send to PLC correctly and pursuant this happen some of networks in the PLC don’t active then we don’t have related output.
This communication is bidirectional as some of measuring data which have acquired by the measuring sensors e.g. thrust cylinders stroke, cutter head speed, steering jacks stroke could not send to screen PC for visualizing.
We found out some of analog input (PIW) addresses switched between items in the data block 40(DB40) e.g. maximum steering jack stroke 250 mm put in via screen PC its real address is d117 while it send to d123 that is reserve.
Finally, we changed some of them by PG or correct them by FC105 and machine is working.
Whereas this matter is important to working of machine continuously and safely it would be appreciated if you tell us how we can solve this problem completely and what have caused this happen?
Hello TBMAleppo;
Could you give details on what PDV software is?
What you describe seems to be a standard HMI project, which requires a communication driver between the PLC and the program that runs on the PC. Once comms have been established, tags (in the PC program) have to be linked to addresses in the PLC so that data exchanges can be correct.
The PLC program should have instructions to transfer data from the protocol destination area to your process DB. Have these rungs been checked? A PLC shouold not "loose" its program easily, if it is battery-protected, or if there is a EPROM card in the memory slot.
What communication protocol are you using between the PLC and the PC? What hardware/software interfaces are you using?
Are the mistaken addresses you refer to in the PC program or in the PLC?
Did they work before and lost their connections somehow, or is this an initial programming error in the PDV software? Are they simply MOVE instructions in the PLC program?
Hope this helps,
Daniel Chartier
Hello everyone, One of our machine we use Siemens Cpu315-2dp. And this cpu communicate with 4 Lenze servo drives series 9300 via profibus. Also...
179
Hello, iam a newbie in wincc operations. But I am a hard/soft engineer. In my father'r company, they have used a wincc based project to...
363
Hello, I'm working on a project in which I need to communicate a Micrologix 1400 series C to a Zebra printer ZD230t through Ethernet/IP. Is there...
747
Good day, everyone, We're trying to establish an S7 connection on ethernet between an S7-400 CPU and a new S7-1200 CPU (which is defined as slave...
2,618
Hi! Last few I've been trying to send message from MicroLogix 1400 to Micro 850. Unfortunately every time I failed :banghead:. Did someone tried...
3,186
