Getting Instance DFB public variable on Unity Pro from Vijeo Citect 7.2
ndelucca
Jul 2013
Rosario
28
Hi everyone, i wanted to ask if its possible to read public variables on a DFB's instance on Unity Pro S, from vijeo citect 7.2 using OPC OFS.
I noticed it is possible to access arrays, so i think this should be available too rigth?. thanks
They are certainly accessible throughout the Unity program. I would suspect they should be availble through OFS, make sure you give the instance of the DFB a name (as opposed to the auto generated name).
Can you give it a try?
I tried to access theese variables like i do with DDT, by using in VijeoCitect, the path name of the variable, i.e: DFB named Motor_1, variable named Failure_1, the direction on VijeoCitect i used was Motor_1.Failure_1. I also tried using the alias! first, but neither of theese worked.
What do you mean by the Alias. When you create a DFB (eg Motor) and then use that in your program it will have an instance name (eg Motor_1), if Failure_1 is one of the declared public variables within that DFB then you can access that variable throughout the program using Motor_1.Failure_1 (In fact you can access any of the Output variables for this DFB as well).
Just remembered there is a parameter for each variable (and also each function block) to make it available to a hmi. If you right click on the variable or in your case the instance of the function block, and select 'data properties' there are a whole set of parameters available, one of those parameters is a selection that will make it available to a hmi
Thanks for the help GeoffC, i tried using the property for HMI but it didnt work, still i was able to fix the issue by declaring the variables as VAR_IN_OUT for the motor block. Its not the safest way to go, but its quite simple.
Hi I am trying to retrive RSLINX data from c#.net application. I have refenced my .Net application to Interop.RSIOPCAUTO.dll. But when trying to...
2,578
The application was working in Twincat 4022.16 Used VM for offline. recently changed the laptop and the getting the error with Message as below...
52
We are using wincc scada WinCC system software V7.5 SP2 , connected to few plc . Past 3 weeks we getting this alarm continously when we checked...
79
I am very, very new to PLCs. I only have experience with Picos, but I knew enough to save this from the dumpster. Apparently, everything on it is...
613
Hi, I tried today to get RD3A and WR3A instructions to work on the PLC and it didn't work, but it worked in simulation. I followed the clone...
18
1,399
