1768 enbt - can't set IP address
italo2008
Feb 2009
Padova
95
Hi all
I have this configuration:
HW
CompctLogix L43
1768 EWEB fw 4.004
SW
Rslinx classic 2.59.01 CPR 9 SR 5
BOOTP/DHCP 2.3
I can't set the IP address of the ethernet module:
with BOOTP utility i see the device, I can set the IP , but when I try to disable DHCP it seems that the utility cannot communicate with the module, so it continue with its requests, it seems that the ip is not set and I can't ping it.
with RS linx i set an ethernet driver but the only thing I obtain is "unrecognized device", with Yellow question mark....
Any suggestion?
thank you
i assume you mean a yellow triangle with an '!' exclamation mark
go into the setup of the new device
check the tabs - there is a final config you need to confirm.
- I dont have the info here
With the BOOTP issue, after you've set the IP address, are your laptop and EWE then in the same range or is the laptop set for some other IP address range? I've made that mistake a couple of times and had to reconfigure my laptop to the correct address range before disabling DHCP in the module. That might also explain why you can't ping it.
Hello Friends I am trying to connect to a Zebra printer. I can print the label with hyperterminal both by RS232 and TCP/IP. Now, I am trying to...
276
Good Evening, I've spent most of the evening working on adding a 1768-ENBT card to connect a machine to our enterprise network. The card is...
1,484
Can a L36ERMS use an ENBT (or other rack mounted ethernet?) module to connect to PoitIO 1734-AENTR? We have a system coming in that has PointIO...
2,625
Hi All, I have a 1768 L43S Guardlogix controller FW 19 with a 1768-ENBT A module in the rack. This unit was purchased 2nd hand, and the...
2,724
Hello everyone, I have two 1768-L43 controllers. In each chassis are two 1768-ENBT modules. In chassis A, there is one with the IP...
2,072
