Red Lion PTV talking to Mitsubishi QJ71E Ethernet Card
Fanucrobotech
Jul 2015
Alabama
Hey guys, new here on this forum. I have connected a Red Lion Productivity station to a Mitsubishi Q06UDEHCPU using the built-in ethernet port and it works fine. However, I would rather connect to a true ethernet card (QJ71E71-100) but I can not figure out the setup because I do not have a MC Protocol option in the "NETWORK PARAMETER OPEN SETTING" on the Mitsubishi side. I have used Network 1, station 1, port 5002, pc 255 and many other different configurations. Anyone have any experience with this setup? Thanks guys
I found this tread from a couple years ago.
Title; "Crimson 3 with Mitsubishi Q06UDEHCPU" from cobra phil. He was able to get the QJ71E71 module to talk to the Red Lion without issues. This is what I am trying to do.
I can get the builtin port to work but not the QJ71E71 module. Can someone help with the Qj71E71 parameter settings (TCP, open system, host port, destination port?
Thanks, Damon
I set up a ProducTVity Station to read data queried from a SQL view. I moved that information into string tags to display on a large TV. I have a...
1,546
Hello guys and gals. Just wondering if any of you have used any good alternatives that are similar to the Red Lion PTV unit. Thanks!
1,783
Can anyone see what is wrong with this program? every time it gets to the Cell2 page it doesn't scroll any further. The goal is to have it switch...
1,464
Hey guys, I'm working with a PTV and am wondering if somebody knows of a way to log the info in the alarm/event viewer into a file other than...
1,719
Does anyone know if a Red Lion PTV or Data Station Plus can connect to a SLC 5/04 over DH+? The Serial port is Used for the PC Based HMI and...
1,570
