Hi all,
I'm currently doing a project which is using Fatek PLC and In Touch Wonderware as my SCADA monitoring. I'm facing problem on the communication part which In touch is failed to pull out the data from the PLC. I check the PLC data through ModScan where all the data are successful being pulled out.
In fact I had tried to use a In Touch IO Server named MBENET (modbus ethernet) but it seems like only for MODICON PLC. Or is there any special configuration need to be setup first for the communication under the "Access Name" in In Touch?
Appreciate if anyone can help. Thanks.
