Help with iFix Variables.
RPax
Feb 2004
125
Hi, I was wondering if you could help. I'am using an existing iFix package/file that I'am not to fimiliar with. Most of the tags are simply selected out of the iFix Database however some of the tags seem to come from Declared variables such as example #control, #Time, #Data (custom made variables in iFix .. I think) and variables such as #GS_X, #RJ_1 etc (created by the program author).
I was wondering where would I find these declared variables (particularly ones created by author)and their associated programs in iFix. I also have the problem in that when I load up iFix for the first time these variables are sometimes not automatically declared (activated) but if I open certain screens they then become active. Would appreciate any help on this. Many thanks - Rpax
In Fix these variables are declared in Command Language scripts. The scripts can be attached to screens or objects such as buttons and can be set to run when the screen loads, is open or closes. You should be able to find the scripts in the properties of the screens which run them.
Hi! I am using ifix first time and looking backup scada to learn things. For Datalink I am using following tag reference and it is working fine...
2,393
Hello, I am working with a system previously developed on a logix500 based slc controller, a new rendition has been made using a compactlogix...
2,303
Hi all,, Can anyone help me in installing the scada ifix software... I have 5 sets of CDs.. is there any one by one methodology in installing...
2,569
I have generated a CSV import file for my database but whenever I try to import, the DB editor just crashes. Is there a way to troubleshoot what...
3,535
Hello. Urge you to help you tell me the code VBA in Ifix 3.5. Specifically, like this: I want to update the operating time of equipment, every 24...
3,925
