Omron Program Software
lenny
Jun 2002
62
I am looking for a source for old Omron program software. The product is a Sysmac Mini SP20-DT-A. I am told that the unit is not factory supported nor is the software avalible from Omron.
Ideas?
Lenny
I don't think there was ever a software package available for this unit...
Sorry, but I think you're stuck using the handheld :(
-Eric
Wow! A software program for the mini? :cool: Thanks for the link, Jay!
And to think I fought with that handheld on the one program I had to do on a mini... Never again! :)
I think I still have an old (original) catalog for the minis... I'll try to find some info for Lenny as well
-Eric
Ok, so I am up, had my coffee and called someone who has the cable. The part number is SP10-CIF01 and it can be ordered from Omron or Omron distributers. :nodi:
Thanks folks........I'm on it. Now we can take a peek inside this machine and see if we can teach it some new tricks. :D
Omron sp20 mini cable
Hello,
I was very glad to come across your post. I am looking for the pinout of a cable that I can use for the sysmac mini sp20 plc. Would you mind using a voltmeter and pin it out for me. It would be a great help.
James
Thanks for the Omron pinout
I have been looking for that for about a year now. I have 6 of these sp20's and was about to throw them out.!!!
Thanks!!!!!!
surprising problem sp20???????
hi,
i have used the mini sp10's and sp16's and now when i come to use the mini sp20's i am confronted with this craziest problem i have ever faced. not sure if the plc has bombed cos i am facing the same problem in two different sp20's.
when i turn the power supply by turning on the key switch all the output contacts are closed. i cant beleive this. i tried this with both 110VAC output and 24Vdc output. but surprisingly when i checked for a short between the output and common i found none.
can somebody help me please!!!!!!!!
thanks,
balaji
i am trying to learn myself omron plc programing techniques / fault finding problems on machinary programmed in cx any info or free software will...
6,358
Hello everyone. I am new when it comes to Omron PLCs. Currently I'm uploading program from CJ1M PLC using CS1W-CIF31 cable only. I connected the...
98
Hi Everyone, I have a customer that needs a CQM1H (CPU51) replaced. They purchased the processor new-old-stock from a source they found online...
320
Hello everyone, We have a PLC Omron CJ2m CPU12, it contains an old program and it is UM read protected by password. Now we have a new program...
525
Hi, i need to make: 1- A PLC Program on Omron PLC CP2E-N using high speed counter E6C3-AG5B 360P/R 2M(Absolute) ,to Reject bottles on Conveyor...
831
