GX Developer in Windows 7 - Help
zai_jnr
May 2008
MALAYSIA
169
Hi all,
I'm using Mitsubishi GX Developer in Windows 7 Professional environment. I'm trying to use Help function inside GX Developer software. But, cannot use due to windows help support screen come out when i try click Help function inside GX Developer. There have any setting i need to do to eliminate window help support screen come out?
Really appreciate for your reply.
When you installed GX version 8 did you install Melsec environment first I think you need to do this. I am running the same as you Win 7 profesional with GX version 8 and my help files run ok so I guess its something you have done. Regards Badger.
thanx for your reply.. normally, when want to install GX Developer, the first thing need to do is to install melsec environment. GX Developer cannot install without Melsec environment.
My GX Developer version is 8.55H. and win 7 Pro is 32 bit type OS..May i know ur GX version and WIn 7 Pro type OS bit?
Hi, I need to reinstall GX developer on my laptop. I used to have it on a windows 7 32 platform but had to do a fresh install and now it will not...
7,984
***NOT FOR PRODUCTION USE*** See disclaimer up top. All of this stuff isn't for production use, but for the home automater / Internet Of Things...
6,601
Hi I'm trying to connect to a Mitsy FX3u PLC from a windows 8 PC. I'm having no luck at all and was hoping somebody might be able to point me in...
4,426
G
I have recently changed my pc. The new one has Windows XP and won't run GX developer FX (V7). Does anyone know what I need to buy or do to get it...
5,837
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
44
