PowerFlex 70 EC Not React to input and still in Not Enabled
philoux
Sep 2009
Montreal
Hi, i recently install a powerflex 70 ec and still saying Not Enabled on the HMI... the safe off jumper is in place and the enlb jumper also. I also try a factory reset but still the same.
all digital input is set to not used exept the input #2 for Run ..... i have no more ideas about that trouble !!1
Thx
Phil
Check!
I Check the input configuration and all input is set to not used... i also check the jumper for the safe off is on pin 3-4.... but the strange think is is when i apply 24+ on input 6 (TB6) is saying Safe Off on the screen but the jumper is present on the safe off connector ???
Problem find!!!
I found the problem is located on the main board. Above the Safe Off connector the R108 Resistor blow up !!
Can find only the main board??? for replacement???
I've got a Powerflex 700 that doesn't like to get going in the mornings. This motor will run anywhere from 30 seconds to 5 minutes before it just...
94
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
143
Hi I was wondering I need to update the firmware of a 755 inverter does the drive hold the program on the drive and just updates the firmware or...
141
Hello everyone, I'm new here. First of all I just want to say that you guys are very knowledgeable and reading your posts on here has saved my...
159
216
