Which RS Linx would be best to use as a OPC Server
Coachman
Sep 2006
Maryland
97
Which RS Linx would be best to use as a OPC server to grab
tags from a Compactlogix and place in a Excel Spreadsheet (XL Reporter)
9355-WABSNENERSLinx Classic Single Node
9355-WABOEMENERSLinx Classic OEM
Thanks in advance,
If you have more then one controller or if you think you will in the future then OEM. Otherwise they will both work. See PDF below
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
184
Not a PLC question but I need expert help on this. My FactoryTalk stopped communicating with the server its hosted on. I had an error stating...
106
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
230
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
141
Hello, We have two stand alone FactoryTalk Site Edition clients running. Recently we've had a problem with FactoryTalk Linx on one of them. After...
99
