Modicon TSX Micro .stx file
woodward_uk
Mar 2006
Hinckley, Leicester
42
Hi Guys
We are currently upgrading a Modicon TSX Micro PLC for one of our clients. I was hoping to retrieve the plant setpoints from the existing .stx file that was provided to us by the client. Does anyone know of a demo version or viewing package that will let me view or print a copy of the software, I understand that the PL7 software can still be purchased but it seems like a big expense for a one time use.
Thanks.
it depends if the 'Setpoints' are hardcoded in the .stx file or stored in memory.
it is possible to backup memory to a .Dat file using PL7 software which is readable with any text editor.
i'm sure someone will printout the .stx file to pdf if you attach it here :)
can pm me ill give you printout. The pl7 software has a 21 day trial if you can get a hold of discs
Hi Chud
I am struggling to get hold of any installation disks, but I would be very grateful if you could send me a pdf printout. It would certainly save me a lot of time.
many thanks
Steve
After updating a panel, I inherited another PLC for my "learning lab". It's a Modicon TSX Micro. I've not worked with a Modicon PLC yet, so I...
128
Pure mind boggled at this one, can’t seem to figure it out. NO contact with - %M130(%MW11) How is this possible? Is the %MW11 0 it’s logic 0, 1...
1,531
Hi All, i have PLC Modicon TSX 3722 Micro i need to know where should i put the socket of programming cable on Ter or Aux port. and i see the file...
1,607
Is it possible to send and receive data with a custom protocol communication for reading inputs and setting outputs? for example via TER...
1,358
Dears, I am trying to communicate with modicon TSX3721001 using TSXcUSB485 cable i purchased the cable from a local Schneider distributor and...
6,870
