FTView SE v7 - Alarm and Event Summary Display Filter
ASF
Jun 2012
Australia
3,921
Hi all,
I have a network distributed FTView SE system, which has three clients, showing alarms for three different sections of plant. I have created filters so that the operators in each section can show only alarms relevant to them, but they don't ever use them. They do, however, complain about the amount of irrelevant alarms that are always there on their screen.
I can define an initial display filter for the display at server level, but that would then apply to all clients. Is there a way - presumably using VBA or a macro - to have each client set it's own display filter when the display starts? I'm OK with working out how to establish which client has called the display, and which filter I want, but I just can't find a way to make it apply that filter automatically.
Thanks!
Well, I should clearly persevere a little more with the knowledge base before posting...
Knowledge Base Article 731118 - Programmatically change the Filter in the FactoryTalk Alarm and Events Summary object in FactoryTalk View SE
TechConnect required.
It's as simple as
Code:
[Alarm/Event Summary Object Name].FilterName = "[Filter Name]"
I'm still recovering from the shock of how easy that was, given how difficult most other things involving Alarm & Event objects in FTView have proved to be :geek:
ASF,
Thanks for sharing. I know the day is coming when I'll have to tackle this and myriad other issues with Alarms & Events on our SE network system. Nice to know that at least one thing with this package is "easy".
Peco ajuda de voces, tenho meu Alarm and Event Summario
no Display Filters criei o nome Padrao - com o seguinte filtro - Alarm Class LIKE `%ALARMES%`, com este filtro visualizo no meu sumario todos os alarmes que tem a classe ALARME.
Gostaria de digitar em um String Input o nome do meu alarme, apos clicar em um botao e no sumario filtrar somente o alarme desejado.
Sera que alguem pode me ajudar?
I help you, I have my Alarm and Event Summaries
in the Display Filters I created the name Padrao - with the following filter - Alarm Class LIKE `% ALARMES%`, with this filter I see in my summary all the alarms that have the class ALARM.
I would like to type in a String Input the name of my alarm, after clicking on a button and in the summary filter only the alarm you want.
Could someone help me?
Hi, I am having some issues with FactoryTalk View SE (Local) Alarm and Event server. In my "active" alarm windows all alarms is shown correctly...
968
Is there a simple way (VBA or macro language) to acknowledge ONLY the most recent alarm? I upgraded recently all the way from RSVIEW 32 7.60 to...
676
Hello all. Is there a way to upload alarm tags at the bit level to my FTView studio? I export them from my PLC thinking I will upload them to...
409
Hi. I'm working on a project with FTView SE 13. What would be the easiest way to beep a sound as a new alarm appear on the banner?
1,070
Hello experts! Can you guide me, please, step by step how to log alarm in my scada project to Ms sql server database. In my project there is some...
1,358
