RSLinx Classic 2.5 quit connecting
moltra
Nov 2005
Ohio
53
I have been running RSLinx Classic 2.5 for about 6 months on a IBM Thinkpad running XP SP2. For some reason I cannot connect to my Enternet/IP network using RSLinx Classic anymore. I have reinstalled RSLinx 3 times now and still cannot see the devices on the Enternet/IP Network.
Any help would be appreciated
A couple of questions that may help us shed more light on what is happening with your network:
1. Which RSLinx driver were you using to connect? The Ethernet devices driver, or the Ethernet/IP driver?
2. Can you ping your devices on the network?
3. Did you (or anyone else) make changes to any configured driver in RSLinx?
Rick
Ethernet/IP, I can pull up the powerflex web page for each drive.
No. No changes did install KEPServer.
Just a WAG, but have you checked your XP firewall settings since you installed KepServer? Perhaps the KepServer installation changed some firewall settings that are now blocking RSLinx Classic.
Obviously, the firewall was not an issue *before*, since Linx Classic was running as expected.
Rick
I started the driver for Internet Drivers and input all ip addresses and I can see them all. But I still cannot connect via the Ethernet/IP Driver.
Do you have VPN software on the computer? I know that the Checkpoint software I have on my PC to remotely access our corporate network interferes with the EtherNet/IP driver whereas the Ethernet Devices driver will work just fine.
If you have that software installed, you might have to diasble the service. Once I disable the service it works just fine. I ended up creating an icon to start and stop the service.
Even if that (VPN software) is not the case, see if you can disable the Kepware Server and see if that re-establishes comms.
OG
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
86
Hey All, I am sorry to ask this, but i still gotta do it. What happens if I close RS linx? Will it cause network interruption and PLCs will lose...
138
Does anyone know if there is a way to import RSLinx Classic data into FT Linx? We have a quite extensive configuration set up, and it would be...
2,489
Hello, I entered my controller IP address as 192.168.1.100 (Local) for 1769-L33ER. It worked fine until couple month and found the controller kept...
1,121
Hi All, Looking for some clarity regards the relatively recent rebranding of RSLinx Classic. From what I can make out from the RA website and...
2,332
