Lost idea build a PLC trainer
Deer
Jun 2002
124
Hi All,
I would like to build a PLC trainer/simulator, I have Digital Input and Output, Analaog Input and Output (0-10 VDC, 4-20mA),RTD module, and High Speed module.
On the front panel PLC simulator there are:
1)Many push buttons that connected to digital input
2)Many pilot lamps that connected to digital output
3)Potensiometers that gives source 0-10VDC and 4-20 mA connected to Analog input
4)Digital displays that will show up value from analog output (example digital Amperemeter will show value when potensiometer 4-20mA was turned or Digital Voltmeter will displaying 0-10VDC when potensiometer 0-10VDC was turned).
5)PT 100 sensor that connected to RTD module
6)Encoder that connected to High speed module(simulating rpm motor with turning encoder by hand)
My question:
What is the architecture to showing temperature value and speed/rpm using digital displays?
Is it good to use Scaling Meter(Digital Display) that connected to analog output (this display will make scaling from 4-20mA to engineering unit)?
Your advice would be appreciated, thanks!
Deer
I would make only very simple display, maybe even in bitmode or just simple, as it is read by normal plc. like hex or so.
on a display however (so in a scada system different story.
but a standard plc does only have simple lights, on a scada almost everything is possible.
i would make some simple screens, 1 for input 1 for output, 1 for registers, 1 for arithmetics, 1 for manual forced things 1 for communication.
but hey it is very basic a plc. however i do know several simulators so why invent the wheel again?
if so i am interested in result or as beta user.
Deer,
our company has stopped constructing our own trainers. We found it better and cheaper to buy them from a firm called Lucas-Nülle . They offer a very good price/quality rate and an excellent service. We couldn't do better and cheaper ourselves.
Of course there are other firms with equal offers.
Kind regards,
hi everyone, I have a problem, it seems that in somewhere on the programming the reference tends to lost mabye one time at day. I write this...
78
Well, not sure what else we can do with this one at the moment. Will chat with Rockwell in the morning but am not expecting much. Guess I'm...
1,117
When E300 powered off, the ethernet device tag data stayed at last know state, for example, fault bit is still Off, ready bit is still ON, status...
997
I'm working with a 1734-AENT PointIO module (manual) connected to a 1769-L30ER controller over fiber ethernet. The 1734 PointIO module has some...
1,040
Hello, My laptop was rebooted lost 500 & 5000 tried to re-install but need to activate, need help badly, Thanks
773
