343-5 all leds flashing
tecno44
Apr 2020
aydin
26
Hello,
i have 315-2pn/db Cpu (315-2EH14-0AB0) V.3.2.16
and to be using with Cp343-5 profibus (343-5FA01-0XE0) V4.0
I guess I did something wrong.
I might have uploaded the wrong SDB files
SDB 1002 1003 in System Data
How can I fix this problem?
Thks for all.
In addition to sigmadeltas suggestion,..
Did you install the U-shaped connector between the CPU and and the CP343-5 ?
And between the CP343-5 and the subsequent modules ?
Did you by chance configure the wrong type of module, i.e. CP342-5 or CP343-1 ?
Response from Siemens call center
Mr. Ufuk,
SDB system data blocks cannot be intervened in any way. You can see the relevant explanation in the appendix. Flashing of all leds of the device means Module fault / system error. The fact that the CP module systematically interrupts a process and the energy fluctuates during the process cause such problems. When the stop led flashes permanently and the stop led flashes, it means start up. If the stop led or run led is constant after this step, communication can be established, otherwise, if all leds of the module are flashing, you cannot configure it because you cannot communicate.
In the attachment, the meanings of the status leds are available in the manual of the product. You can examine.
Hi everyone, I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU...
167
Hi, I have a customer with a S7300 from around 2013 which they link to approx 25 inverters, 3 DP to DP converters and 5 IM153 remote I/O units...
320
Hi , Looking for some help. We have a 343-1 PN Lean Card & 315-2DP connected to an external system collecting data. After a recent shutdown...
63
I've been called to a site to assist with an ASi fault. The line has been down for a couple of weeks following a failure of the ASi power supply...
1,300
I have an S7-300 and an HMI. The HMI is the only device that talks over Profinet through the CP343-1 module. It's run fine for a couple of years...
502
