1762-IF4 Hardware Switch and Software setting for Signal Type?
theColonel26
Feb 2014
West Michigan
783
It seem there is hardware switch and software setting for signal type one the 1762-IF4?
I have a project that I inherited, the hardware swtich is set to current input, and that is what I want. But I just noticed that in the IO config for the card in 52 500 it is set to -10 to +10V.
I have a pH signal that outputs 4mA at 0pH and 20 mA at 14pH.
If I set the IO config to 4-20mA. What should the raw input range be?
  • 0 to 32768 ??
  • 6553 to 32768 ??
And last it should indeed be set to 4-20mA in the IO config right? otherwise I relay am just getting a voltage signal and not a current signal. Correct?
Yes, set the IO config to match the hardware switch.
31206 20 mA
6241 4 mA
unless you have it scaled for PID in the config.
then
16383 20 mA
0 4 mA
I have 1769-IF4 module and 1766 micrologix 1400 series B controller, when connecting Analogue input in module it's showing maximum values of...
1,662
Greetings to everyone, my question is: How can I Read a thermpcouple typej ona an analog module (1762-if) on an allen bradley micrologix 1400 (rs...
1,271
Hey All, I'm still pretty new to PLC programming, and in particular how to translate Allen Bradley's documentation into real world information...
3,384
Hardware: Micrologix 1100 & 1762-IF4 Analog Input Module Problem: I have one 4-20mA transmitter hooked up to I1:0, I am monitoring the current...
3,366
I'm having an issue with an Allen Bradley 1762-IF4 input card on a MicroLogix 1400 series B. The input to the card is a Futek CSG110 strain gauge...
1,734
