Steve Bailey
Trying to do some debugging for a friend. Project is a G307K2. Running Crimson 3.0 Gold Build 707.000.
The application has tags that are calculated based on values entered in Data Boxes. I put the tags modified by operator entry and the calculated tag into a Watch Window. When I run the emulator and set the Watch Window to "View Online" I can see the changes I make to the tags but the calculated tags show "n/a". The calculations are done in a program that is triggered on change in value of the operator modified tags. Does the emulator not run the programs?
