Connected Components Workbench: Why won't my I/O Change states on my PC
jleif81
Mar 2016
Sterling
Im running CCW for the first time. Im using version 8.01. (Version 9 didn't allow me to stay connected) So I'm connected and in Remote Run mode. The ladder program I loaded on to the Micro820 is running. Im expecting to see the Inputs and Outputs change state on my Laptop, but they are not. Has anyone ever experienced this?
From the VIEW menu select toolbars and make sure debug is check. Now when you download a program to your plc you have the option of starting and stopping debug.
You must be in debug mode before you can see events take place in your ladder program.
I hope this helps.
Thank you for the input, but that did not work. I tried running CCW on a different computer (My Desktop) and connected to a Micro820 and it worked!! I also noticed in the Global Variables that the cycle timers and a couple other variables were timing, changing states and a lot of red indicating that it was online. These same variables don't work on the problem PC (Laptop). And there is no red. I'm fairly certain that I have all the right .Net Framework install because it should have been included in the install of CCW. Any Suggestions?
No, I don't, sorry. I have an issue with CCW and 820 that I can't get into RUN mode, can debug program but can't put PLC into run mode as a standalone.
What version are you using? A tech at AB told me they are having a lot of trouble with 9 so he told me to use 8.01...
Just to update this thread. The PC that I am having trouble with is running Windows 7 Professional. Ive connected to the Micro820 with 2 other PC's and was able to monitor online with no problem. Those 2 PC's that worked were running Windows Enterprise. (Also one was using CCW verison 8.00 and the other was using version 9.01)
UPDATE!! I finally got CCW to work correctly. Turns out I had some corrupt registry files. I uninstalled CCW and deleted any program files that I could find related to CCW. Then I used rededit.exe to delete any registry files associated with CCW. Restarted. Reinstalled and Ta-da!!
was trying to use Connected Components to connect to a 525 drive via usb with the face off but can't seem to connect to it. the screen lights up...
789
So I'm using CCW to program a panel view and this is not my first I have done many. My Problem is I get an error message that I have never seen...
495
How do you expand a branch in connected components workbench. Example i want to add an interlock around more than one contact. Most software you...
1,282
I’m working on a conveyor project for work. We’re trying to install a few diverts to carry product directly to one of two trailer doors. I have...
1,051
I cannot get CCW to add a controller, i keep getting a error message saying that the device is not authorized. This happens with any model and...
1,368
