Standalone Pulse Input Servo Drive with fixed Advance/Retard speed
Huckleberry
Sep 2013
Illinois
I am looking for a standalone (no PLC required) servo drive that I can set up to follow an incremental encoder at a fixed ratio AND will allow me to use drive inputs to advance/retard the servo at a fixed rate (that I program into the drive) WHILE geared to the incremental encoder.
In other words, I would like to use a 3 position spring-return-to-center switch to advance/retard a conveyor at a fixed rate WHILE geared to an auxiliary encoder. So no matter what speed the servo is running while following the encoder, it will "superimpose" a move at a fixed speed on top of the gearing
I have done this several times in the past, but every solution that I have found has required some sort of external source (PLC, HMI, etc.) in order to accomplish this.
Does anyone know of a servo drive that can do this without a PLC?
Check out the Yaskawa Sigma7Siec. Single axis servo amp with integrated 61131 logic controller. That's as flexible as you're going to get for the money.
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
108
I want to monitor a couple signals in a place where there is no PLC but there is ethernet. I know I can use an AENTR or Flex I/O and a module but...
21
766
This is kind of a beginner question. Let say I have 2 Rockwell PLC talking to an InTouch standalone installation. Let call them G1_PLC and...
1,129
*VMWare vCenter Converter Standalone version 6.3 & 6.4 Hello Experts I want to convert my current physical hardware machine to a virtual...
1,616
I'm using a Do-More BRX to push data to a shared server via HTTP Post, and receive commands from the server in the response. It's not a critical...
2,394
