RSLogix Micro Starter Lite - How can I add a 1746-IB16 card into the IO config?
Ecnal
Oct 2015
Belleville
All:
If this is possible, I would like to add virtual a 1746-IB16 card into the IO configuration. I'm using the RSLogix Micro Starter Lite software. Currently I can only select from a list of 1762 cards using the MicroLogix 1100 Series B 1763 processor.
Reason: at school we are using RSLogix 500 with a 1747 processor and 1746 cards. I would like to be compatible to transfer written programs. Is this possible.
Ideas or direction are welcomed.
thanks
ecnal
You can't add 1746 IO to a MicroLogix 1100.
You can however add a 1762-IQ16 and the addressing will be similar. Then you can just export your PLC program as a .slc file and import the rungs back to your 1747 project.
Be aware there are a couple instructions available to the Micro1100s that don't exist in the SLCs if memory serves.
Thanks Dravik
I appreciate the response.
Do you or any members know if or where someone can obtain a free copy of RSLogix 500 or is that just not offered?
thanks
ecnal
I don't believe, outside of the starter edition, that a free version exists.
You may want to find out who the School's AB rep is, and ask about a potential 'student edition', They may have something available or be willing to help.
Then isn't posible to add in rslogix 5000 1746-ib16? iam converting a plc-5 projrct to a rslogix 5000 and i want to keep this remotes i/o digital and analog how can i cofigurate them?
Salaspelayo, that forum thread from last year was related to MicroLogix and SLC-500 controllers.
Your question is a little different; you are converting from SLC-500 to ControlLogix and want to migrate the existing I/O to a remote network adapter, probably the 1747-AENTR.
I would recommend starting with the SLC to CompactLogix Migration Guide, which focuses on slightly different platforms but has some information on using the 1747-AENTR.
And also get the User Manual for the network adapter: 1747-AENTR User Manual.
If you have specific questions about a PLC-5 system that was previously using SLC-500 I/O on RIO and migrating that combination to ControlLogix, please create a new topic thread and provide as much context and detail as you can.
Hello, first assignment with A-B stuff. The CPU is a MicroLogix 1000. Have a serial interface, so RS Linx Classic to edit the driver (AB-DF1) with...
1,691
Oh, I hope someone can help! I have one little problem holding me up from studying this weekend. I'm using Rslogix micro starter light, it's a...
2,987
I am using RSlogix Micro Starter for a personal project and currently have it installed on a desktop computer. Soon I will be moving my project...
2,204
I've created a test program in Micro Starter Lite and attempting to set up communications with the emulator and run the program. In the...
1,577
Well, the title kind of speaks for itself, but I'm curious if the micro starter lite version of logix 500 is still around, every link I've tried...
12,347
