Exchange of DBs between S7 400 and S7 300 plc through profibus
Apr 2014
India
I wanted to establish a profibus communication between 2 plcs. One is S7 400 and other is S7 300 plc.
Please let me know what is the right method of doing so.Till now I have followed the below steps:
1) Setting up S7 connection in Netpro in Step7
2) using the connection ID in GET and PUT blocks
3) THe S7400 plc is using GET and PUT to exchange the DBs in S7 300 plc.
I think I have done most of the program correct but I unable to simulate in plc sim.
Please let me know if the followed steps are correct or not and can we perform such simulations in plc sim.
Regds,
Hiamsnhu
Do you have integrated Profibus or is it an external module?
If integrated, you can specify the number of inputs and outputs for each PLC and just use direct addressing. No need for using GET/PUT. Never actually used those for Profibus, just ethernet.
Might be easier.
Hi all. I'm trying to set up communication between a 1756-L72 (EN2TR) and a 1756-L82 (CPU port) using produced / consumed tags. From the L72...
366
Hi All, having a bit of a hard time getting EGD communications working on Emerson CPE310. SO far i'm just trying to configure 1 Exchange of...
449
Gents, I've a Beckhoff TwinSAFE project in TwinCAT 3 where I've 2 EL6910 Safety controllers, and need to exchange data between them. So I...
829
Hi, Has anyone tried here to work with Mitsubishi FX3U as controller 1(connected thru serial) for Mitsubishi HMI E1071 then AB Compactlogix as...
1,508
How to do that can any one give me the how to write instructions example
837
