purvisl
I am a newbie with Omron. I have a customer with a C200H-CPU01. They have purchased the C200H-IP007 peripheral unit to connect CX-One Programmer. I have a USB-CIF02 cable that I purchased off the internet. I powered down the unit and mounted the C200H-IP007 and then powered the unit back up. I connected CX-One Programmer with the USB-CIF02. I tried the auto online feature and CX could not connect. I would see the comm light on the IP007 flash as CX-one tried different settings. I then went on a manual hunt of setting to try to communicate but had no luck. I have several questions:
1. Do I need to use the CQM1-CIF02 (ie the USB unit has issues)?
2. Do dip switches on the front of the IP007 need to be in a particular position?
3. If I punt and add a C200-LK201-V1 to an empty slot, can I get online after powering up or will this fault the processor until I get online.
This PLC is 2 1/2 hours away from the office so I want to get all ducks in a row before heading back out.
The unit also has a C200H-MR831 memory module and has one empty slot.
