Magelis HMI Upload Question
Martindag
Sep 2009
quebec
227
Hey guys,
Just recently started using Schneider PLC.
I just started playing with a Magelis HMI with a program already build in it from someone else. i can connect to my HMI and PLC no problem with USB and Ethernet but when i try to upload the current HMI program i can't select the Main Drive. I only see the secondary and optional drive for some reason but they arent there i got no USB key or SD Card on it.
I was wondering also if there is a way to go in Configuration like in a Panelview to to manualy copy my program like on a USB key.
My HMI is a HMIGTO5310
Thanks !
The problem is the program loaded on the screen must have the upload option enabled when originaly downloaded to the screen. Otherwise there is no option for you to upload the program from the screen
I've seen a few old threads on here that say there is no way to upload from one of these HMIs unless the developer took the step of downloading...
2,654
I have a TSX P57102 PLC and XBTF024510 screen. The screen is connected from the 25 pin port to the term port on the plc. I tried to connect to...
6,570
Good morning friends. . We are having a problem with one of our machines that have two HMI consoles connected to the same network. They have...
1,112
I am looking at a bakery oven that has been dismantled and in storage for unknown time, it was manufactured in 2012 so not that old. my gig is to...
3,614
The above HMI does not power up and is located on a Caribbean island. This started after a 24 hour power outage. It has power now but the screen...
1,207
