simple Ac Drive with Advanced Motion Controller
Kataeb
Jan 2007
www.livelovelebanon.com
628
Has anyone tried to use a simple Ac Drive with an Advanced Motion Controller? To do a low cost angular synchronization on machines (Rewinders) having big power Ac Motors? With a Position master (motor) followed by Position slaves (motors)?
For example, using a Siemens Simotion module to control several G120 (CU250S) or Micromaster (440) drives, in Position Loop?
Thank you
I assume this post is tied to the dc motor to ac motor retrofit post...
My opinion is S120 motor modules/ smart line module with 1PH8 motors, 1500 or 1500T cpu
Yes it can be done
You must use a good quality VFD recommend Yaskawa A1000 I flux vector mode
I have done it more then a few times
I have used ACS800 drives from ABB to control servo an induction motor and woks perfectly. My PLC is a Controllogix, servo module 1756-M02AE.
Cheaper options are the S120 and Yaskawa A1000 thru EIP.
Due to customer's requirements, i am trying to reduce the cost by using G120 instead of S120 (about double price).
But my concern is that G120 might not work well with angular position loops.
My question is how does wire "C" respond Does wire "C" mimic the output wire "A" or Does wire "C" mimic the input wire "B" thanks, UKB
2,696
Hi all, Writng a FB in ST on Beckhoff TC for a pulser which turns on and off on a cycle, is paused by turning bControlInput to FALSE, but resumes...
65
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
248
I have a program that does a 7 second "scan" sensor calibration routine whenever a setting (setting is called assistance level or "AL" and ranges...
172
Hi all, I have a simple question that I have overcomplicated and gotten stuck on. I have a variable, we can call it "light" that I need to stay...
214
