looking for a sample RSNetworx for DeviceNet file
Lovell
Feb 2013
Saskatchewan, Canada
120
Hello fellow programmers,
I am looking for a DeviceNet file with at least 1 VFD (powerflex70 and 700 if possible) and 1 E3 for parameter review and example of input mapping. Could someone post a file? (*.dnt)
Either that or tell me how to add the devices manually offline?
Thanks!
p.s. im on RSNetworx for DeviceNet V11, RSLinx 3.9
Not sure about V11, as I use V21
But V21 creates a network with drag and drop.
The LHS Box has lists of hardware.
Your E3 is listed under Motor Overload
Your Powerflex 70/700 are under Smart MCC
Like anything Rockwell, you may need to the correct version of software/EDS files to have them listed, so use the Tools\EDS Wizard to load up the EDS files for the devices you need. Get the EDS files from Rockwell (www.ab.com I think has them).
Then drag and drop onto your network.......................
I found the way to add hardware offline in my RSNetworx for DeviceNet V11 - it is under the View menu, toggle hide or show by clicking on Hardware. Not sure how I was blind to this before.
I need to locate a better sample pump than this. While these work, they just aren't built for years of service. 120V supply and in a damp...
2,740
Hi, I have been in training courses since year and half now, and I gained a good knowledge in PLC and SCADA,I did many assignments in the course...
1,798
Hi, I'm new to the forum and PLC programming in general. I've done a lot of block type programming using HP VEE (now Agilent VEE) designing ATE...
2,141
126
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
200
