" do not care for AC connection " is this statement correct ??
magdyfayad
Aug 2007
cairo
245
frequently , i hear this statement " do not care for AC connection but must care for DC connection "
who say this statement wants to connect " L " terminal and " N" terminal any connection for AC connection , but for DC it must connect the positive terminal to a certain terminal and the negative terminal to a certain terminal
but i have some questions :
1- if this statement is correct , why the devices which worked by AC marked their terminal by " L" & " N " ??
2- what happen for AC devices if i reverse the connection for " L" & " N " ?? I know if the ground is connected to the nuteral and when i reverse the plarity , then the body of this device will be have a voltage , is there any thing more ?? i.e : if i reverse the polarity for AC devices , they also work , or not work , or damage ?? or different from some devices to another and what is the difference ??
3- the contactors either operate by AC or DC , we do not care for their connection , as if i reverse the connection for " L " & " N " or for " +ve " & " -ve " the contactors will also work , which means the statement is not always right , am i correct ??
4- when i must care for the connection for both AC & DC devices ?? what is the theory for this ??
thanks in advance
if you are going to do the job properly then you would wire correctly to the terminals as marked.
AC can be switched around, use the bridge rectifier as a good example of this. Should your component have its ground linked to nuetral, (unlikely) you reverse the connection then bang!
The polarity of DC will effect your LEDS and solenoids relays etc.
Nothing worse than grabbing a supposed nuetral and getting a belt cause some a hole was rough. Prove test prove I know, but come on
thanks
i know i must connect correctly , but i want to konw if any one revercse the polarity what haappen ?? what happen for AC device which does not contain bridge rectifer , or any AC device must contain bridge rectifer ??
thanks
Hi
This statement is not correct.
In some cases it might be true.
For DC. some DC devices MUST be connected in right direction.Other wise they would damage or not work.
Some devices like contractors or relays lamps,can work anyhow.
My conclusion.You better understand what you have in hand before you power it.
For AC.My rule of thumb.If you have 2 wires(without ground)device it is not important.
If you have 3 wires.Open your eyes.
In some cases you might connect the HOT(220V Phase)to the body of the device and kill someone.See my conclusion.
The theory behind it sometime it simple sometime its not.
There is different rules in different country's.
What excepted in US is not excepted in Europe or over here.
The problem is where you ground the center of the feed transformer.At that point you get the ground point and the neutral point.Grounding the center its like grounding the minus of power supply.
To be on the safe side you have to pull 3 wire from that point to your device(trough the panels CB etc).Any short cut might hurt someone.Some places you can pull the ground from local point,like water pipe.in that case you might get bed quality of grounding.
You have to learn the safety rule of the your place.Before you play with AC/DC over 50V.
AC Device don't need any rectifier there is not polarity in AC.
The importance of polarity in AC is which point will be referenced to the ground, if existing or needed.
Hi
thanks
you said : " For DC. some DC devices MUST be connected in right direction.Other wise they would damage or not work"
i know that but when theses devices donot work only and not damaged , and when donot work and also damaged ??
you said : " For AC.My rule of thumb.If you have 2 wires(without ground)device it is not important "
why then marked the two terminals by " L " & " N " if it is not important ?? or it is marked terminals by " L " & " N " for only three wires i.e : contain ground ??
you said : " To be on the safe side you have to pull 3 wire from that point to your device(trough the panels CB etc)."
do you want to say if the nuteral is sepatred to the ground is more safe as if the nuteral for any reason carry some voltage the body of the dvice is still zero voltage as the ground is insulated to the nuteral , do you want to say that ??
but i ask , cannot the ground wire carry some voltage also as the nuteral or not ??
magdyfayad said:
Hi
thanks
for exemple if device has switches wich obviously operates in L wire it is important when u switch it off all circuits have 0 potencial. Also some circuit elements operates as switches if they go ofline maybe they protect circuit in some cases. For exemple if u have device witch is not stationary then it is uninportant if u change L with N, if it is constructed properly and can be pluged everywhere.
Some DC component would not work if they connected in wrong way.and some would damage.It depend on quality of the component and manufacturer wish.
There is no rule for that.The only rule I know is if the voltage is high or not stable the component might damaged.
When I wrote " For AC.My rule of thumb.If you have 2 wires(without ground)device it is not important "
I mean from the point of electricity it is not important.
If you take lamp it will work either way .
From the point of safety you need to connect in the right way.
L&N cam to indicate the hot and the neutral for safety reason.
To clear the issue.
I think it more safe to use separated conductors for ground and neutral(Even they cumming from the same point).Ground conductor should not carry any voltage.
You Wrote "but i ask , cannot the ground wire carry some voltage also as the nuteral or not ??"
Defiantly NOT.
All the safety system base on the ground cannot use the ground as conductor.
do an apprentiship or read a book.
Just connect to as marked and you cant go wrong, and when you know enough by experience then connect how you see fit.
Are you licensed to be working with electricity??? Doesn't sound like you are?
Well said, but look up his other posts, there is history with this one !!
As others have said, the concern with AC is safety, not function. I remember back in the school days, the instructors telling us about working on TV's with non-polar plugs. Some TV's had grounded frames, that if someone had changed a plug, and not paid attention to L / N, then the Hot wire would be connected to the frame of the TV. No problem for the customer, the TV worked fine.... but not good, for the Tech, who may be taking the insulated cover off.
-Mur
thanks who answer me !!
this site for interactive questions and answers only , not for ironic !!!
i ask here and all can ask and any one can answer but by polite method only !!
if any one speak with me by impolite method and i can also speak by the same method but i do not do that because i am polite and i want to learn only !!
i say again i entered this site for learning only not for unuseful speaking
magdyfayad
I would suggest you to learn the AC issue very carefully.
WE can help but not give you the foundation.
Pay attention to the safety rules.
Mistake might be disaster.
In most of the country's you need a license to work with more then 50V.
Ironic ?
You can take this as Ironic or however you want BUT:
You show such little understanding of the principals that you are dealing with its hard to believe that somebody lets you loose on any equipment that they own.
Do you realise if you do some of the things you show your apparent lack of understanding of you may actually kill somebody ?
This is not really the place for learning such basic electrical principals however, college, university or an appenticeship is.
There are thousands of superb text books which will explain all you need to know about your many questions, of course people here will help you where they can but you may get several different answers, no of which would be admissable in court if you do injure somebody !!
I urge you to stop playing with different theories of L&N connections, questioning reverse polarity, worrying about single phase vs three phase terminology and actually go and learn the basics !!
i am very careful for the connection for both ac & DC drvices but i asked only to know what happen if any one reverse the polarity for the device ?? and also i asked why i hear this statement frequently " do not care for AC connection " although we have marked " L " & " N "
I reapeat again i am very careful when i connect the power supply for any device !!
  • Locked
So there is a lot of hype going around if you read the internet or watch the news... anyone here preparing? have you started to see it hit your...
405
271,127
Hello, people. I'm trying to download .deh file into Prowirl 200 flowmeter using DeviceCare SFE100, but after connection I've got a message...
1,548
Headline: "Hackers halt plant operations in 'watershed' cyberattack" ...
5,619
Hi All, I am trying to set up a flowmeter (FCI ST98) using Fiedcare or PACTware with Profitrace proficore ultra, but when I add PROCENTEC...
2,235
G'day gentlemen, We are setting up a E+H Fieldcare installation and don't seem to have any problems with the E+H instruments, however when we...
2,279
