2stroke1971
Ive got an SLC500 rack that I want to use for some hands on learning.
SLC 5/05 CPU
Ive got RSlogix 500 v 8.10.00 cpr9
RSLinx classic 2.57.00
When I try to go online with the PLC I get the following:
Init failed code-1
Current driver (Linx Gateways) may not be running
Any ideas? Ive reinstalled linx...
ive disabled the firewall.
Im running an XP computer.
Is this specific to the ethernet connection?\
if I used a serial cable would that bypass this issue?
Thanks in advance.
SLC 5/05 CPU
Init failed code-1
Thanks in advance.
