alive15
Hello, I getting the above fault on my Kinetix 350 drive(2097-v33pr5-lm), using studio 5k on laptop.. This system has ran good for the past 2 years, so here is what I have done. I have checked for any mechanical binds first, which appear good. However, I received fault again after running 3 parts.
Next, I unplugged both feedback and power cable on motor side and connectors appeared good on cable, and the pins looked good on the motor itself. After plugging these back in, I received same fault after few parts.
Next, I re-cycled power on entire machine (which restarted the servo drive). Currently, it has ran for the last 30 minutes or so, but I'm sure it will fault out again soon, so looking for potential ways to troubleshoot this?
The manual says to check the feedback connections. How else can I check this cable? Is this just a mere inspection to make sure it looks good, or is there something I can measure using a volt/ohm meter?
Also, I read elsewhere that re-running hookup test and auto-tune is very helpful, so I may try that next. Any other tips or recommendations are appreciated.
Thanks!
Thanks!
