MSG Instruction in an Add-On Instruction -RSLogix 5000
Cleaner
Jun 2004
Atlanta
Does anyone know how to, if it is possible, setup a MSG instruction in an Add-On Instruction in RSLogix 5000. I want to create an AOI to gather data from a drive, via the MSG instruction. I can put the MSG instruction in the AOI and declare it as an In/Out Parameter variable of that AOI, but I cannot edit the settings inside the MSG instruction. When I click on the three-dot-box to configure it, I get this error in the status bar at the bottom of RSLogix:
"Ladder element field is non-editable. Invalid Message tag in corresponding operand."
I'm not really sure how it would work anyway, since the setup of the MSG would contain variables into the AOI.
Anyone got a way around this?
I added an AOI that I wrote for a CIP MSG instruction. I use two message tags and two DINT tags for the communication to a second PLC (read and write) and I am able to configure the message tags in the ladder view. Maybe ther are some restrictions when you try to change it online, I can't remember. Hope this helps.
Msg controllogix micrologix
hello all
I have a problem to set a msg data to read from a micrologix 1500 using a NET ENI to communicate via ethernet, I'm using a CompactLogix and MicroLogix not appear in the browse to define the path and I do not appear in the form of MSG
THANKS
AB do an example AOI for the SM2 module which includes messaging to and from Flex 4 and 4M drives. The messages read and write parameters and also connect to HMI to visulize these parameters. You'll need to experiment - some of the code is qutie advanced -particularly the drive recognition code, It uses some addresses which I've not been able to duplicate.
Paul.
87
Hello all, I am currently trying to establish a message instruction to pass data from a 1756-L73 to a 1756-L71. My communication path from the...
352
Hello Friends I am trying to connect to a Zebra printer. I can print the label with hyperterminal both by RS232 and TCP/IP. Now, I am trying to...
276
Can Anyone tell that How Msg Instruction comes under Unscheduled communication and How System Overhead time slice(SOTS) function connected to it...
968
Studio5000, V31 I'm Messaging a MassFlow Meter, specifically to pull the Engineering Units (units of measure) for 6 instances. Basically, do I...
1,203
