FactoryTalk Network Distributed
AlexLLF
Jan 2019
Missouri
Hey guys,
I am trying to view some HMI's of ours, three of our processes are on Network Distributed, need to figure out how to view them in offline project and also through SE Client. When I try to open the Client on my computer it says "Application '***_***' does not exist." Need to know what to do to be able to access it. Please and thank you.
I’m not sure what you mean by “offline project”. A local application, but still connected to the PLC’s over the network? We have our distributed application duplicated in a local project, built by duplicating the RSLinx config, images, global objects and HMI tags; then adding in the displays and changing the paths to match the local RSLinx. A bit of a pain setting it up the first time, and some network functionality goes away (Historían, mostly). We don’t have the events, they are still running on the distributed system.
I built up a spreadsheet to assist with FTAE and screen updates, essentially changing the path (removing areas) as needed so updates are less painful.
#1, you can't see them offline.
#2, all must come from the SAME FactoryTrash Directory server to connect a client to them, otherwise, you have to change the target FT directory.
Alarm Server Connection Status I am trying to tie a color animation to a rectangle that changes color when connected or disconnected from the...
477
Hello, I am trying to make a copy of a FactoryTalk SE Network Distributed application. I want to make modification but do not want to work on...
1,154
We are cutting over a PLC5 to ControlLogix and we ran into some issues with the HMI (FTView v10, Network Distributed). We found that after...
942
Hi Folks, I am having a bit of trouble with a Factorytalk View Studio Network distributed application (Surprise surprise) after restoring a...
1,083
Hi everyone. I'm working with a network distributed application, just a HMI server and a HMI client. I installed the SE Server package on a...
2,124
