CAT5E for Start/Stop Transducer Cable
JackPW
Feb 2018
East
I'm extending the cable (to 100ft total) for an MTS temposonics transducer with Start/Stop output that will be in continuous flex.
Would Continuous Flex rated Shielded CAT5E be a good choice here? seems like a good fit.
I have an application where I need to run Cat5e cable from a Rice Lake 920i weigh indicator to an ML1400, about 150' apart. There is an existing...
2,297
I need a flexible and slick CAT5e/6 cable to run in conduit. Suggestions?
1,769
Greetings, There appears to be a debate about weather or not to terminate BOTH ends of the shield of STP CAT5e cable. Normally with signal...
7,872
How to fix if appears code “$115 plc-restart running” on the screen OP17
244
Hello everyone, I'm new here. First of all I just want to say that you guys are very knowledgeable and reading your posts on here has saved my...
161
