Prosoft Flow Computer MVI56/69-AFC opinion
Bullzi
Jun 2012
Colorado
1,530
Hi everyone,
Has anyone on the Forum used the Prosoft Flow Computer before? What was your opinion of it? I am quoting a well pad job and was looking at the MVI69-AFC for the flow computer. Please give me your thoughts.
Hi everyone,
my opinion is will the meter techs be able to understand how to configure and calibrate it? Any meter tech will know how to calibrate and configure a totalflow. You 'may' save a little bit of money by going with the mvi69-afc over say a microflow on each of your meter runs, but long term, it will cause much more confusion and heartache.
Its kind of like using a PLC to act as an alarm for your home. an you do it? yes. The next guy up may not be appreciative though. So I recommend going with industry standard.
I agree with diat's assessment.
On a multiwell pad it's pretty cool to have an all in one solution but as nice as afc manager is it's not nearly refined as other products plus they are scared to log into it some of them think it will ESD the site. Also flow checking is not as easy. You can have multiple ones in the same.rack depending on needs. Its modbus compliant for scada.
I've used them with good success, but they are probably not the best choice for a wellpad imho.
I've been using a ABB XRC to do most of the measuring on a 12 well pad. My two cents.
C
Hi... I have a problem with MVI56 module which flowrate and total volume are not updated. This happen after we run the module about 6 weeks. No...
3,443
CathyR
C
Hi, We have an application that has a device that goes through a reboot (appears un-graceful) What then happens is the MVI module appears to hang...
59
I am working on setting up a Prosoft Datalogger model PLX51-DLplus-232. This unit will be collecting data from a SLC 5/05 on the DB9 port set to...
95
Hello. I am trying to use a Prosoft AN-X4 to improve the communications for a new panelview plus 7. This is going from a SLC-500 through DH+ to a...
276
Hi. I'm using a Modbus ProSoft where I basically map data to a big INT array. Example, where GX_I_63HPU is a REAL, MNETC.DATA.WriteData[200] an...
21
419
