Telemecanique with Siemens HMI-OP17
ccsPLCGuy
Oct 2005
Singapore
Hi Guys,
Anyone ever try to connect PLC Telemecanique TSX7 with CPU PMX 87-455 and HMI Siemens OP17?
or some work that similar to connect between 'old' PLC Telemecanique TSX7 and Siemens HMI (any tipe similar OP17 and TD17)?
In Siemens Software "Protool/Pro" manual is mentioned that Siemens Panel HMI (e.g. OP17) supports Uni-Telway bus.
If we choose the Uni Telway bus at software "Protool", there will be choices of many different kind of Telemecanique Uni Telway driver that can be uploaded to Siemens HMI-OP17 (so that OP17 has a native driver of this CPU):
- TSX SCG 1161
- TSX7 with P47 411
- TSX7 with P.. 420
- TSX7 with P.. 425
- TSX7 SCM 21.6 K. 1
- TSX37 / 57
However, I did not find
Telemecanique TSX7 with CPU PMX 87-455.
Please help me if you have some experience on it.
Thanks.
Kwik
I have no experience with Telemecanique or Uni-Telway.
But I think that there is a good chance that it will work with one of the other CPU selections.
I believe that the CPU selection defines what number of variables are avilable in the PLC. If you can chose one that is as close as possible to the one you are using, then it should work as long as you are only using addresses that would exist in the selected CPU.
An experiment will reveal if it is possible or not.
Hello I am trying to get connection between old Telemecanique TSX47-411 (or TSX 87-425) with Siemens HMI. Protool and WinCC Flexible manuals say...
4,530
Greetings Is it possible that Siemens plc is a plc telemecanique cp343-1 module that is connected to the module ETY110ws able to exchange...
4,255
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
230
Hello! Sorry for the unusual question not quite on the topic of the forum. We have a computer museum. We got an old PLC programmer telemecanique...
1,625
Good Afternoon , I'm not too familiar with the Telemecanique Compact Smart Relay SR2B201BD . Is the software free , and would any of you...
1,571
