Strange issues with AD POV and OPC
sparkie
Nov 2014
KS
1,146
I'm using RSEmulate 28.11 with RSLinx Classic OPC Server and POV 8.1 to build an HMI. I'm getting a strange problem.
I have a tag for tank temp setpoint. It is an integer tag. When I go to write any value into the setpoint tag, it seems to "overflow" and also writes into a timer address, like the write is getting split up over several address.
Example: I enter any number, and I get "4" back for my tank temp, my setpoint writes to zero and I get negative numbers on my tank cycle timers. It is like the OPC server is splitting the value up over several memory addresses, perhaps the value is too big? Without the HMI running, something in the PLC keeps overwriting the values for Counter.CU and Counter.DN as well. I have to restart the emulator to fix this.
Found the issue. I had an incorrect length with a copy instruction, so it was overwriting other tag's values.
I have tried to resolve 2 strange issues I am having with RSLogix 500. I have tried to figure them out myself and called Rockwell tech support but...
5,772
Hello all, I am facing an issue with my Commander SK that I cannot solve on my own, I am struggling on it since several days :confused: The...
1,030
Hi. I'm doing an upgrade of an old 1400e to a new panel view plus 7 standard using ftv studio v 12,which will be communicating to a slc 5/04 via...
2,608
Can someone explain the jumper between the elements? Does it do anything? See attached jpeg.
681
We have an OPC server getting data from a Compactlogix PLC. The PLC also communicates with a Panelview and a couple VFDs via Ethernet/IP...
1,157
