cdrum543
Hi everyone, I was just wondering what your thoughts are on using Rockwell's Automatic Device Configuration. How has it worked for you? Have you experienced any issues using it? Tips and tricks. I've read about it, and understand a bit on how it works, not much experience with it past the bench.
I am working on a project and had suggested using ADC since the project involves a large number of PF525 drives. Already using NTRON managed switches which can be setup with Local IP port setup (assign IP to device based on port). PLC is a CompactLogix L33ER. Management had issues using ADC on previous projects and didn't want to risk using it again for this project.
I just want to learn as much as I can about it. Thanks!
