How to handle DDT and DFB types from Unity Pro with Vijeo Citect
MCMZ01
Oct 2012
Groningen
Good morning everyone!!!
I'm starting to use Vijeo Citect 7.2 with an existant project of Unity Pro. Inside this project we have declared the alarms as a variable of a DDT Type which contains a Array of words. At the same time we declared a function that it's an Alarm Manager of an DFB Type which contains all the data to handle the alarms.
I'm new into this kind of variables, because I always used specific variables from specific locations, and all the system of the alarms is well handled by the PLC and, of course, my alarms system and variables doesn't have a valid location that can help me to handle this as a variable tag in Vijeo Citect.
Have any of you any idea how can I handle this data in Vijeo Citect???
Many thanks in advance!!!!
I saw that it's not possible to use these variables in Vijeo Citect because it simply doesn't support these variables. But if someone had my problem and have found a solution of this I would appreciate it!!!
I am working on a project using AB PLCs and PanelView HMIs. There is a desire to allow control loop setpoints to be provided through the HMI or...
3,647
I've used Banner for RTD's, thermocouples and 4-20's but not for discretes. I called the factory to find out whether either PNP or NPN wiring...
1,434
The hole size to mount a through door handle is 65mm to 70mm. I can not find a punch that will work in Stainless Steel. What are you using to...
1,125
Hi; We have below mentioned softwares for PLCs, PVs drives etc. I want to ask what is the best practice to handle these softwares, should we...
2,929
If you get a cold call to come out and work on a system with ControlLogix and PanelView HMI, how can you determine which major firmware revisions...
3,767
