Comunications between Micrologix 1400 and Sew Movidrive-B
d4n1_g
Oct 2013
Argentina
Hi guys,
I need know if someone achievement communicate a Micrologix 1400 with a Movidrive-B.
If so as it has done and what protocol to use and communication cards to use in the Movidrive B.
A have a project for a industrial machine that use four Movidrive B for positioning 4 servomotors all must be controlled by Micrologix 1400. I always program Rockwell PLC and I don`t like change :angr:
Also programing C , that is the lenguage to program the Movidrive-B and one solution can be install a program in Movidrive B memory and control all with digital I/O, but I would like made throw IP.
The two companies said that both have incompatible comunications protocols because the Micrologix 1400 use [FONT=&quot]PCCC protocol instead of CIC[/FONT] and Movidrive B use [FONT=&quot]CIP Motion [/FONT].
Some Idea???
Thaks a lot
🔨 Saturday morning early we had our control net communications go down on our flex logix racks. We have 3 pc’s & 6 Racks & 1 powrflex 70 on...
3,267
Hi All I have a lot of TI and S7 PLC as well as AB. I have a SMS Module from AB from which I am sending SMS notifications out. I want to do the...
2,713
Hi All, We have a Bosch PLC/CNC system running a lathe. I have a problem that while the machine is standing still I keep getting a measuring...
1,774
39
I'm trying to write a data in Arduino using MODWR function block .I used the code I got from online for both PLC and Arduino. I made the wiring...
79
