Monitoring backup battery in a compactlogix system.
Apollo
Mar 2009
Malmoe
Im wonderring if the is a system variable or its possible in an other way to get information in to the PLC code about the backup battery on the compactlogix controller? What I mean is if the battery is bad it will activate a variable in the PLC code, that for example can be shown in a HMI system...
The system Im using is 1769-L32E
I haven't done this, so I thought it might be interesting to look this up...
Under Help, look at the GSV instruction.
There is an object there called "Controller".
Further reading about this object leads to the Minor & Major fault codes
There is a Minor Fault code for Battery missing or in need of replacement.
So, you may be able to get battery status using a GSV instruction
A GSV will do what you need.See attached image.
Hello everyone! I need to connect to a DL205-1 CPU and, as far as I know, I need to use DirectSOFT 6 software for the connection. Is anyone...
62
Our punch press has a SLC500 with HELM weight module (HM-604-WM) for tonnage monitoring. The operator enters the weight range on the HMI, which is...
201
Hello, I have been trying to figure out how to connect to and monitor a DLR that is on a remote rack from my PLC. The local has a 1756-L81E and...
117
Good day, we have 15 analog inputs, we need to log the data in excel and monitor these values through web browser. We're planning to go with Delta...
120
I have several plc’s that I’d like to monitor Into our SCADA when the comms break or plc faults. These are (SLC-505 & Compact Logic PLC’s) I...
743
