Front panel mount integrated PLC/HMI needed
AlecTek
Sep 2010
Vancouver
155
Hello,
Anyone can recommend a front panel mount integrated PLC/HMI which has 3 analog input (4-20mA 12bit). 4 Digital Input and 4 Relay Output or less is acceptable.
Thanks in advance!🤞🏻
Thank you nonuke. Actually I am looking for similar products as Unitronics JZ20-R16 which they don't have in stock now. Do you have other brands in mind?
I've used the Pro-Face LT series and had good luck. Only down side is you're limited to your screen size as I think a 5.7" is the biggest you can get. They also have I/O expansion modules that snap on the back of the unit in addition to the embedded discrete I/O.
These things are an absolute PITA - too much wiring to the door. Better to use a panel mounted PLC with a comms cable to the screen in my view - saves heaps of time and wiring and the more expensive screen/PLC combination is more than covered by not having to waste time, wiring and money wiring heaps of stuff to the door.
I think Horner have one with expansion I/O that mount in the panel rather than on the door which would be much better.
Hello all.... I am not asking you to fix my issue just a little guidance is all i am asking. I just started with a new company and I am working...
2,604
Dumb question..... what is the actual name of the front panel of any card that fits into the card itself? It is the part that has all the screw...
1,616
I have a project where the customer specs will not allow the use of the VFD's STO safety function. They demand dual safety contactors in front of...
18
1,886
Anyone have any good or bad experience with the 755 series drives from AB that have the Active Front end? I have to approve something for 3...
1,787
Does anyone know if the front face of the terminal block can be removed for ease of connecting the wires? I'm referring to the screws circled in...
2,183
