Simatic I/O Error 16# 494D No relevance for user (Z1): 0000
metaller
May 2004
Bratislava
86
Hello there, does anyone know, what means this kind of error?
Here is the diagnose:
Event 10 of 10: Event ID 16# 494D
STOP caused by I/O error
No relevance for user (Z2): 0000 (Z3): 0000
Previous operating mode: RUN
Requested operating mode: STOP (internal)
External error, Incoming event
Thanx for any reply...
If you click on "Help On Event" on the module information form, you get the following:
Possible causes:
S7-300:
A module was removed or inserted illegally.
· S7-400:
Failure of the module inserted/removed monitoring or error in interrupt servicing due to a defective module or due to removing or inserting a module illegally.
To correct or avoid errors:
Based on the system status lists, check the current I/O configuration detected by the CPU. Compare this with the existing configuration to see whether there are any defective modules.
· Bus error in the local or distributed I/O
To correct or avoid error:
To remove the error, you must switch the device off and then on again. If the error still occurs, check the bus connection and interface modules in the distributed I/O. Make a note of the HEX code marked as "Not user-relevant" in the detailed information for the diagnostic buffer entry and contact your manufacturer.
· This error can occur when an expansion device is switched off, for example, if an IM module is defective.
To Correct or Avoid Error:
Replace the defective module.
Thanx a lot... We should check if any module is'nt defective. They said, that this error comes usually twice a day, wonder if there is some module that is used only so few times per day...
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
164
I don't know if this is the right place for the subject at least I'll try. The company has one of the oldest computers that is a master Windows...
740
Good afternoon, I have a Simatic S5 / S5-135U with three CPU 928B. The PLC is not operating due to a BASP error. On two of the CPU boards only...
1,056
Hello Friends I have this error in a MP277 8" Touch. The "\Flash\Simatic\PDATA.FWX" configuration file could not be loaded. The application...
4,786
Dear All,, We have a Siemens Simatic S5-95U and there is stopped red LED active Tried resetting the PLC,switching the Run/Stop toggle push button...
3,041
