Sending Messages from ControlLogix to AutomationDirect ViewMarq LED Display
Rob S.
Sep 2008
Maryland
739
I have been searching for some examples of sending messages from a ControlLogix PLC to a AutomationDirect ViewMarq LED Display. Would you have any links to any examples , and is it difficult ? I did some messaging with a Cognex camera system several years ago , and they had some great examples , but I have not found anything related to the ViewMarq.Thanks for your input.
Since you are going to use the display on a Logix platform, theoretically, you could connect the display to the CPU's Serial RS232 port and send ASCII commands and STRING data to the display.
In practice, it will be preferred to add a third party 1756 ASCII module to to the Logix Local chassis and control the display via Serial RS232 ASCII commands while displaying CPU originating STRING type data.
ProSoft's MVI56E-GSC is one of the best out there.
http://www.prosoft-technology.com/P...ic-ASCII-Serial-Enhanced-Communication-Module
There are examples within all RSL5K installed packages Rev.16 (this is my oldest install)or later.
C:/RSLogix 5000/Projects/Samples/ENU/V.x/Third Party Products/ProSoft.
There are also examples, Add-On Profiles, .EDS files, User Manuals, etc. within ProSoft's product web page.
Hi, I have a Micro 1400 that I have a project for. I am trying to make it send and receive data via UDP. I have followed the Rockwell guide but...
1,463
Hi, I am trying to restrict the number of messages sent and received via MicroLogix 1500 to SLC 5/05. Right now the MicroLogix is...
1,018
I am attempting to write a LD5000 program that will use Internal programs to optimize the design. For example, I wrote the program heavily...
2,500
Hey guys. This is my first time delving into UDP commands, at least from a PLC standpoint. My setup is as follows; Productivity 2000 PLC...
17
6,364
Hi, I am a complete beginner with CODESys and have been tasked with programming an IFM CR1084 screen to communicate with another device, over...
1,558
