I have a FactoryTalk ME application I'm trying to get working to interface a PanelView Plus with a Micrologix 1100. It is used for demonstration purposes and will be moved from one network to another frequently. I'm curious as to whether or not the HMI can be setup to locate the PLC by a DNS name as opposed to having the device path/IP hardcoded in the HMI application. I would prefer to use DHCP addresses on both the HMI and PLC and not just the PLC. But within FactoryTalk, in order to setup communications, it looks like the HMI must have a device path assigned for the PLC that includes the IP address. So once I move it to another network, that IP would no longer operate with other machines on that new subnet. This demo unit will possibly be moved around between 5-6 different subnets.
Is what I'm trying to do even possible?
Thanks.
Thanks.
