Jasondelane
I have a Powerflex 753 and want to control a water pump using the analog input on the main board. I have a current pressure transducer. If I use the Analog In P50 value as my speed reference, can I set the minimum at 20ma(or the min ma value that matches my maximum required water pressure) and the max at 4ma(or ma value that matches the minimum required water pressure) so that the drive increases speed as the pressure drops?
This would act as a feedback loop to slowly ramp up the pump speed to only what is necessary to maintain the water system pressure without using a separate PLC.
Thoughts?
Thoughts?
