RSLogix 5000 Controller Organizer Sluggish Online
EJSControls
Apr 2020
Conover, NC
20
Hi all,
Do any of you know how to correct lag within the Controller Organizer while online with a PLC? Scrolling through my tree is very choppy. Sometimes I have to go offline to navigate fluently.
I'm running RSLogix 5000 V19.01 connected via Ethernet.
I've searched the web and tried a few suggestions but nothing has worked.
I have had the same problem, and changing the ethernet card did the trick.
Cheers
Mark
This seems like a software issue not a connectivity issue.
From what I have read, some versions had conflicts with other software such as Acrobat Reader. I have also read some things about routine execution timing problems. One of the solutions was changing internet options for certificate revocation. Some people just blame it on the lack of quality of the software.
I hope to find somebody that completely got to the bottom of the problem step by step.
You may be able to adjust the system overhead time slice to smooth out the lag. Its the ratio of time spent on the continuous task versus background stuff like communications. You should find it under the controller properties box. The advanced tab. We usually run ours between 20 and 33% Sounds like yours may be set lower.
I am trying to get all of the controller tags from a RSLogix 5000 project into an excel spreadsheet along with the style, data type and...
1,455
Hi All, I have a PID control application that I would like to get your opinions on. As I am reality new to PID loops I am struggling somewhat...
4,271
I am trying to make a new project in RSLogix 5000 but the controller isn't showing up when I try to make a new project. I am using RSLogix 5000...
5,672
Hi all, I have an existing project and I am modifying it to my project since they are similar. I noticed the controller types are different. Is...
3,767
Hello, this is probably the dumbest question, but I've been stuck for 2 days now. I'm running RS Logix 5000 standard edition. I create a new...
6,583
